I am a novice level Hyperworks user.
I am trying to run analysis on a part I designed in Solidworks. It is actually a sub assembly of two parts. It was converted to an IGES file and imported as such into Hypermesh. I performed a mixed type of tetramesh on it and after defining the material property as Aluminum, part property Solid, defining the load collectors and the load steps.
When I use Radioss, it gives me the following error :
A fatal error has occurred during computations:
Element # 57457, element type TETRA.
RAM: 171 MB total, 546 MB used.
Data arrays: 161 total, 126 allocated.
DATA SET size 26 MB, ram_disk 2 MB '
From my understanding, it has something to do with the mesh element numbered 57457. I am unable to find where that element is located. I did try a number of automesh and element cleanup tools, as well as tried to remesh with different types of meshes and sizes.
However, I am stumped. Any insight on this issue is appreciated.
Thanks.
