Error #192 programming error. HELP!
Can someone please help me troubleshoot this error? I am new to Hypermesh and do not know how to locate the problem here.Kindly see the picture attached for more details.
Thanks /emoticons/default_wink.png' alt=';)' srcset='<fileStore.core_Emoticons>/emoticons/wink@2x.png 2x' width='20' height='20'>
PS: I notice that it occurs when I update a topology design variable to have minimum member size of 1. Without this update the file gives me a result (only problem being an abrupt and incomplete topology result). I thought the missing minmember size was the problem so i update that but this causes the programming error #192.
Tried changing into a higher minmum member size. doesn't work.
Guys, I was told by someone that this error apparently is a software & mesh problem. Usually caused by using the same model on a number of different computers and the advice I was given was to restart the meshing or the model fresh on a single station…
I tried redoing the mesh and the error was gone /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
