Message id: 44 - Segmentation violation
Hi everybody,
I'm doing explicit analysis on solid geometries with RADIOSS and, every time I launch the simulation, this message appear:
I've controlled if there are any shell elements, but there aren't any of them in my model.
What is the problem? this message is not really clear.
Luke31
Hi Luke,
Please share the .out files.
0 -
Hi Luke,
There are no errors reported in the starter out file. Please share the engine out file (_00001.out).
It will be easy to analyse if you can share the model and engine file (_0000.rad and _0001.rad) too.
0 -
Can I share via dropbox?
0 -
i can share the file: this is my last attempt.
Regards;
Luke31
0 -
Hi Luke,
Please find the files. Penetrations were also cleared in the model and the model is running fine.
0 -
Is there any other problem other than penetration in my files? Or was it the only cause?
0 -
Hi Luke,
Empty node groups were there, which were deleted and cleared the penetrations and the issue was resolved in your model.
0 -
Do you see the empty node groups in the set collectors or in the geometry? Regarding penetration, is there a tool that allow to detect them in Hypermesh?
Sorry if I'm doing a lot of question, but I want to learn my errors in order to avoid them the next time /emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
0 -
Thank youvery much! I'll read the help about this topic.
Besrt regards,
Luke31
0 -
dear @George P Johnson,
I tried to correct myself the issue tha you said me in the wrong model (delete empty set and fix penetration), but the problem still persist. Have you fixed something else?
Luke31
0 -
Hi Luke,
Only penetration fix and model clean (delete empty sets) was done. Please check in starter out (_0000.out) if any warnings are still reported.
0 -
Seems strange. Please upload the starter and engine files.
0 -
do you mean to share in this post? or to save again?
0 -
Please share the files here. I'll just check.
0 -
Hi Luke,
Please uncheck the Heat Input flag in the material law and try running the analysis.
