Hi Mo,One additional question - is there a character set that would indicate a line break if I utilize the search and replace functionality in the utility? I have found that I can add a line break using Word if I replace a repeating character with ^l, but that means copying the text file into Word, running search and replace and then copying the results back into text format back for trapping with Monarch. It would be nice to use the utility for the search and replace part, if it can do that. So far, nothing that I have tried in the utility seems to get me the desired results in applying line breaks.I do like the fact that I can replace the pipe with another character set, since the pipe is a reserved character in trapping.Thanks again,Rebekah------------------------------Rebekah Operational Risk AnalystExchange Bank (CA)-------------------------------------------------------------------------Original Message:Sent: 01-07-2020 08:04 AMFrom: Mahmoud AbdolrahimSubject: Text file has no line breaks - how do I parse this?Hi Rebekah,If the file is created by Unix OS, then each line should have a line feed (ASCII code 10). Try opening the file in DPS using text delimited option.If the file does not have any line feed, then you may try the Monarch utility program.This program is installed on your PC as part of Monarch installation.After you start the Monarch utility, select prepare file for Monarch (Replace, Inset line breaks, EDI) option.select a folder where the file is saved, and also select an output folder.on the next panel there are 4 options. You may try one of the first three options.You may send me a sample report and let me look into it.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840------------------------------Original Message:Sent: 01-06-2020 02:25 PMFrom: Rebekah TyrrellSubject: Text file has no line breaks - how do I parse this?What is the best way to deal with content that is a big block of text without line breaks? Is there a way to add line breaks prior to creating a trap?Also, the report uses the the pipe as a deliminator and is poorly formatted for data mining.There appear to be two ways the data is displayed:Alpha-numeric Record Name | Unknown | Account # | Account Type | Name | email address | Unknown | Reason for returnorNumeric | Account # | Account Type | Name | email address | unknown | Reason for returnBut in order to work with the fuzzy data, I really need some line breaks first - any ideas on an approach would be greatly appreciated!Rebekah------------------------------RebekahOperational Risk AnalystExchange Bank (CA)------------------------------"
Hi Rebekah,If the file is created by Unix OS, then each line should have a line feed (ASCII code 10). Try opening the file in DPS using text delimited option.If the file does not have any line feed, then you may try the Monarch utility program. This program is installed on your PC as part of Monarch installation.After you start the Monarch utility, select prepare file for Monarch (Replace, Inset line breaks, EDI) option.select a folder where the file is saved, and also select an output folder.on the next panel there are 4 options. You may try one of the first three options.You may send me a sample report and let me look into it.RegardsMo ------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840-------------------------------------------------------------------------Original Message:Sent: 01-06-2020 02:25 PMFrom: Rebekah TyrrellSubject: Text file has no line breaks - how do I parse this?What is the best way to deal with content that is a big block of text without line breaks? Is there a way to add line breaks prior to creating a trap?Also, the report uses the the pipe as a deliminator and is poorly formatted for data mining.There appear to be two ways the data is displayed:Alpha-numeric Record Name | Unknown | Account # | Account Type | Name | email address | Unknown | Reason for returnorNumeric | Account # | Account Type | Name | email address | unknown | Reason for returnBut in order to work with the fuzzy data, I really need some line breaks first - any ideas on an approach would be greatly appreciated!Rebekah------------------------------RebekahOperational Risk AnalystExchange Bank (CA)------------------------------"
Hi Rebekah,You can use the Monarch Utility program and replace a pipe character (|) with another character (Replace all instances of a string with another string or an empty string.), however, you can not use the utility program and replace another character with carriage control & line feed.The find & replace in the utility program is in text mode, not hex mode.If you don't have Notepad++, you can download it (its free) and add the HEX-Editor plugin. you can open your file in the Notepad++ switch to Hex editor and replace a character with CC+LF (0doa), per screenshots below: RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840-------------------------------------------------------------------------Original Message:Sent: 01-07-2020 01:51 PMFrom: Rebekah TyrrellSubject: Text file has no line breaks - how do I parse this?Hi Mo,One additional question - is there a character set that would indicate a line break if I utilize the search and replace functionality in the utility? I have found that I can add a line break using Word if I replace a repeating character with ^l, but that means copying the text file into Word, running search and replace and then copying the results back into text format back for trapping with Monarch. It would be nice to use the utility for the search and replace part, if it can do that. So far, nothing that I have tried in the utility seems to get me the desired results in applying line breaks.I do like the fact that I can replace the pipe with another character set, since the pipe is a reserved character in trapping.Thanks again,Rebekah------------------------------RebekahOperational Risk AnalystExchange Bank (CA)------------------------------Original Message:Sent: 01-07-2020 08:04 AMFrom: Mahmoud AbdolrahimSubject: Text file has no line breaks - how do I parse this?Hi Rebekah,If the file is created by Unix OS, then each line should have a line feed (ASCII code 10). Try opening the file in DPS using text delimited option.If the file does not have any line feed, then you may try the Monarch utility program.This program is installed on your PC as part of Monarch installation.After you start the Monarch utility, select prepare file for Monarch (Replace, Inset line breaks, EDI) option.select a folder where the file is saved, and also select an output folder.on the next panel there are 4 options. You may try one of the first three options.You may send me a sample report and let me look into it.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840Original Message:Sent: 01-06-2020 02:25 PMFrom: Rebekah TyrrellSubject: Text file has no line breaks - how do I parse this?What is the best way to deal with content that is a big block of text without line breaks? Is there a way to add line breaks prior to creating a trap?Also, the report uses the the pipe as a deliminator and is poorly formatted for data mining.There appear to be two ways the data is displayed:Alpha-numeric Record Name | Unknown | Account # | Account Type | Name | email address | Unknown | Reason for returnorNumeric | Account # | Account Type | Name | email address | unknown | Reason for returnBut in order to work with the fuzzy data, I really need some line breaks first - any ideas on an approach would be greatly appreciated!Rebekah------------------------------RebekahOperational Risk AnalystExchange Bank (CA)------------------------------"
Monarch Altair personal SLC inserting smart line breaks in a long block of text
too long to post here, see github
github https://github.com/rogerjdeangelis/utl-monarch-altair-personal-slc-inserting-smart-line-breaks-in-a-long-block-of-text
community.altair https://community.altair.com/discussion/comment/5674?tab=all#Comment_5674?utm_source=community-search&utm_medium=organic-search&utm_term=monarch+excel
