hi can you please tell me step wise procedure that how to calculate springback effect with the change in angle after forming procedure?
Hi Sumit,
Please refer to the tutorial HF-3040: Springback available on HyperWorks help. This tutorial has the setup procedure for performing SpringBack analysis.
yes i refereed this procedure but the problem in results that are the software giving springback angle is in 0.5 deg. but if we form the same part on tool experimentally the results are formed and found as in 15 Deg. then whats wrong in the procedure? please suggest solution so that i can get results near about the actual results..
Where can I find this tutorial for springback?
