while running solver stops and error written in .out file.
this shows the error
I hope you are running this in Hyperstudy using Radioss solver.
Please make sure before loading file in Hypertsudy that input deck should be free from error.
Regards
Rahul R
it is free from error. it runs fine with design variable as thickness but give error in case of shape design variable
The files are in zip.
please check nominal run file i.e. .out file.
in it the errores are mentioned
