hi I have got the static thermal simulation complete & now I want to use vel,pres,temp, eddy field from static thermal analysis for further analysis. I tried using acuproj command to write nodal initial condition (.nic) file. however its throwing some error as follows.
'data out of order: expected <nSpecs> found <mask> in binary file <ACUSIM.DIR/test_soln.1_150_0.rst> token <14> near <mask>'
can some one help resolve this problem & write .nic file
thanks.
