Query in Split Element using Curve/line
Altair Forum User
Altair Forum User
I am writing a script for automating blot assembly creation.
Some components like washer is having slot (OB Round) hole.
Initially I am creating 2D mesh and later I will drag it for each component.
Please find attached the image for understanding my query.
I have considered one quadrant and creating the base mesh. And then creating ruled mesh for each layer.
After creating the mesh, I want to split the elements using slot profile.
After splitting, we should maintain the Slot profile exactly.
And mesh should contain Only Quads.
But I am not getting right way to do this splitting
Please suggest a way to do this.
If any alternative methods are there for this type of mesh creation, that is also welcome.
Thanks in advance.
Hari Krishnan. EL
<?xml version="1.0" encoding="UTF-8"?>post-36330-0-94005300-1425045355_thumb.p
<?xml version="1.0" encoding="UTF-8"?>post-36330-0-83918500-1425045356_thumb.p
Welcome!
  • Altair Forum User
    Altair Forum User
    edited March 2015
    Please suggest me a approach for the above problem.
    Kindly let me know if any difficulty in understanding the problem.
    Thanks and Regards,
    Hari Krishnan. EL
  • tinh
    tinh Altair Community Member
    edited March 2015
    Thanks and Regards,
    Hari Krishnan. EL
    I think you should create quad-only mesh between slot profile and OD
    then drag that mesh to form Hexa
  • Altair Forum User
    Altair Forum User
    edited March 2015
    I don't think you can make 'quad-only' mesh with this kind of geometry.
  • Altair Forum User
    Altair Forum User
    edited March 2015
    Hi Tinh and Nguyen,
    Thank you the replies.
    I have attached the expected output of the mesh (Manually created).
    We need some approach to achieve this kind of mesh.
    Thanks and Regards,
    Hari Krishnan. EL
    <?xml version="1.0" encoding="UTF-8"?>post-36330-0-10641200-1425622019_thumb.p
  • Altair Forum User
    Altair Forum User
    edited March 2015
    Don't forget that : quad elements with 'bad quality' can't give you better results than triangular elements, from point of view of FEA.
  • tinh
    edited March 2015
    Hi Tinh and Nguyen,
    Thanks and Regards,
    Hari Krishnan. EL
    Hi
    my approach is:
    1) make a surf
    2) make profile lines
    3) cut the surf by the lines
    4) mesh quad only on sub-surfs
    5) extrude to form hexas
Welcome!
Welcome!
