Hello there,
I am the beginner of customization. I am wondering if i can use any code in the script to run static analysis or optimization automatically. and then import calculated stress and strain data to further calculate maybe summation or minimum value of those data?
I tried to record and reuse the command from I manually run the analysis, but the program stopped after a fem is generated. It did not pop out hyperworks solver view.
Basically, after i open the tcl script and input variables, it will not stop till the final result.
Thank you for your help
Alan
