Hi All,
Would you please tell me how do i know max. and Min. element and ID from my current hypermesh Model?
Thanks
Hi All, Would you please tell me how do i know max. and Min. element and ID from my current hypermesh Model? Thanks
You can 'renumbering' element/node ID to control min/max.
I mean how to know max./min IDs used currently on the FEM. it will help me renumbering of elmenet and nodes.
Hello @Ray_Airbus,
Greetings!!!
I believe you could open the .fem file using notepad, and scroll down to Node cards and Element Cards.
There you could see all node/element number in ascending order.
This works for .key file(LS-Dyna). Hopefully, it should work for other platforms as well.
If you find any other, convenient way, please do share.
Thanks & Warm Regards,
Akshay S Patil
Hi
In panel Tools>renumber
select elems and click 'min/max'
you will see on message bar
Thanks Tinh. You always give me the right answer!!
