Error while importing .nas file to Acusolve
Updated by Altair Forum User
Im facing an error while importing surface mesh in .nas format to Acuconsole. PFA the snapshot of error window.
I double checked in Hypermesh for any free edges, duplicates or connectivity issues, even check for 2D mesh file is also fine.
when I tried the same model in .inp format its working fine in acuconsole but .nas is not!
Thanks,
Elvin
1 - 2 of
21
I'm using CFD Acusolve profile,
Attached are the export options available, there is a fluent option which saves the mesh in .msh format and then there are Nastran (Fluent) as shown in the attached image. I have been trying with these nastran options but no luck!
Are you using the CFD (General) or CFD(AcuSolve) profile for export. Using either of these profiles, export as Fluent(Nastran) format, not the normal Nastran format.
