I am using Compose 2019. I would like to use matplotlib in phyton to plot some figures. However, I need to plot them as undocked figures. Could this be possible?
I created an example to better explain the issue. Attached you will find a .oml file and .py file. The oml file creates the variables and plots a simple figure. You will see commands which adjust the position of the figure on the screen. The oml file also exports the variables to python and calls .py file which plots the same figure in the Python window. I would like those two figures in the same position and size. Is that possible?
Thank you
Berker
