Dear sir,
We are commercial users of Hyperxtrude software 11.0. We use the software for simulating the extrusion process and optimization of parameters. Now, We need to simulate hot compression testing of samples. Is it possible to simulate the compression testing using hyperxtrude where the profile of the sample changes continuously with time. I need to generate the sample profile with time, first in extrusion, then in compression testing.
Kindly help me.
Hi Chetankatam,
You can do extrusion testing. Can you please explain the compression testing with a sketch? So that we understand the process.
Good afternoon!
Joining the question of the author of the comment, I also had a problem when using the Hyperxtrude 11.0 software. Please tell me how to solve the compression test situation? Unfortunately, as a sociology teacher, I am not very good at software. You can see this for yourself by looking at the specifics of my activities using this resource https://expert-writers.net/persuasive-speech
Thank you in advance for your reply!
