I want to do batchmesh of engine component. Please tell me how to mesh with Rtria? In parameter file Rtria option is not available
Hi Alekh,
In batchmesher the available element types for meshing are mixed, trias and quads.
Instead you can use Mesh>>Mesh Controls panel. Mesh controls are used to automate and streamline the meshing process.
Select the surface to mesh and there you will get the option to input the element type as R-Trias. Create a mesh in the Mesh Controls tab by right-clicking on the Surface Mesh and selecting Mesh from the context menu.
Please check this topic also, which is similar to your query:
