🎉Community Raffle - Win $25
Join and Win
Element boundary condition routines
User: "Prabin Pradhananga_22497"
Altair Community Member
Updated by unknown
Hi experts,
I am having issues running element boundary condition routines like udfGetEbcNQuads(), udfGetEbcType(), etc. I am currently using momentum source. Do I need to specify name of the surface set? if yes, where to define and how to get it done?
Thanks!
1 - 3 of 31
    User: "acupro"
    Altair Employee
    Updated by acupro
    From the User-Defined Functions Manual:
    udfGetEBCType():  This routine may only be called within an Element Boundary Condition user function.
    udfGetEBCNQuads():  This routine may only be called within an Element Boundary Condition user function.
    In other words, those routines are not valid for MOMENTUM_SOURCE type = user_function.
    OP
    Updated by unknown
    You meant to say that it can be invoked via a particular surface set and I need to use only those user function that can be used with surface set ???
    And momentum source is the element set not surface set right?
    What are element boundary condition user functions? Where are they applicable?
    Thanks!
    User: "acupro"
    Altair Employee
    Accepted Answer
    Updated by acupro
    Thanks!
    Those particular routines can only be used in functions called by the ELEMENT_BOUNDARY_CONDITION command with type = user_function.  Basically this might be when you want to set some specialized boundary condition on a surface that is not 'covered' by the general boundary condition types.
