3D Tetra Elements not showing in LS-PrePost/DYNA
Hello,
I imported my geometry into HyperMesh and used automesh to generate quads on the surface.
I then used volume tetra to generate 3D tetras and then deleted the 2D elements on the surface.
When I export my model to DYNA keyword file and open it in LS-PrePost, it is missing the extra pyramid elements at the surface.
E.g. 2D view in HyperMesh:
View of surface using mask option in HyperMesh.
Surface in LS-PrePost:
Any thoughts on why this is? How can I retain the elements at the surface?
Thanks,
Petros
1 - 8 of
81
Maybe he want to keep quads as a cover comp
@PetrosYou can split pyramids into tetras by panel 3d>split>solid elements
switch to 'split into tetras'
Shift F6 split quads into trias before tetramesh
