Hi,
How to convert Acusolve .log file to .h3d file format. If i direct try to import .log file in hyper view, its getting crashed. Could anyone please share me the procedure.
Thanks,
Venkatesh
hi,please try my procedure as below image:
Generally conversion to H3D is not needed. I believe that 2019 release of HyperView had a bug with importing AcuSolve log files directly. So a update to 2019 or preferrably 2020.1 should be fine with reading the .Log file, provided that ACUSIM.DIR is also available in the same folder. Only .Log file is not enough for results.
