Hello all,
Does anybody know if it is possible to set and/or delete attributes in Python API?
In short, I wanted to assign a node to a beam element and for that I have my collector "element" and I wrote:
element.directionnode.__setattr__("id",node)
This only works if there is a prior node as reference for the orientation of the beam. If the beam is not oriented based on a reference node (therefore, is referenced by a vector) then it does not work.
I get the message:
AttributeError: "id"
Same thing happens if I want to remove a node from the attribute with
delattr(element.directionnode,"id")
Any clue if this is possible to do?
Thanks
