Continuous engagement with Rapidminer
dear all,
Im a member of this community since jan 2020 and have gone through couple of Rapidminer academy courses. In this aspect,
i looking forward to have avenues to engage myself with rapidminer and to further enhance my knowledge in the process.
1. Do the data science competitions like 'Kaggle" accepts solution from Rapidminer. I dont see much discussion
about such competitions in this community.
2. Any resources to solve various use cases in machine learning using Rapidminer?
regds
thiru
regds
thiru
1 - 5 of
51
@sara20 thnks for your reply. I was looking for discussions on how to use rapidminer on various types of available
datasets.
datasets.
hi @Thiru - we used to run data competitions here on the community for RapidMiner users and we usually run one every year at our annual Wisdom conferences. Unfortunately no, Kaggle has not yet seen the light on RapidMiner and is stuck in a code-only world...
As for ML use cases, there is a large variety in the Samples, Training Resources, and Community Samples repositories. The latter even contains a decent chunk of data sets from the UCI library. Are you looking for something else?
Scott
Scott
@sgenzer
hello
Can we send our paper for wisdom?( I mean that the only papers that we do with RM)( may be we can not come for the wisdom)
Regards
Sara
hello
Regards
Sara
1 - 1 of
11
Scott
Scott
Hello
For your second question, I recommend you to read papers. Also don't forget that the data is generate every day in different places so this data show a way for future, in this situation we should process it.
I hope this helps
Sara
