🎉Community Raffle - Win $25
Join and Win
Impact Analysis With RADIOSS
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear Altair team,
The fact is that I'm about to execute an academic project as Quasi-Static-Analysis with RADIOSS, so I've got several problems due to my level of beginner in that field and also to the complexity of that mechanism; for this reason I'm  writing on this forum in the hope to find some answers to my questions.
Firstly I would like to know how to define the impact force between two solids (impactor+head) and as a consequence the path of the energy flowing through the mechanism?
The second point is how to create a pre-stress in a bolt?
P.S.: I've attached a file with a picture, which shows the form and the components of the mechanism.
Thank you so much in advance.
Best Regards
Lamzoughi
1 - 1 of 11
    Altair Employee
    OP
    Hi Lamzoughi,
    For this loading you have to apply the load using /CLOAD (concentrated force) option where you have to create a Force vs Time function. Between the impactor and head create a Type 7 interface and also necessary contacts between the parts.
    And create a rigid for the below nodes and create an output block for the rigid (/TH/RBODY) from which you can extract the required forces using the time history file (T01) in HyperGraph.
    Since you are a beginner please go through our tutorials in Help menu and also go through https://www.youtube.com/watch?v=CxM52wP3_ew&list=PLQ7KUGFuVz4u5y3SvIEIU07427-gATaG6  which is a webinar on RADIOSS.
