In this introductory API tutorial we will demonstrate all the basic steps needed to create and compile the Hertz-Mindlin contact model plug-in, using Visual Studio. A similar procedure can be followed to create any other API model, compiling a Contact Model being a necessary step to create a new custom physics model.
The main focus is on:
