Flightstream tools
Overview
This extension adds a new "Flightstream Tools" ribbon.  It provides an easy way to export a meshed model to Altair Flightstream in the OBJ format.
The export tool allows the user to select the components to export and select the file to export to. The organisation of the mesh will be respected in the OBJ file produced and will be reproduced in Flighstream.
At present the export tool is the only function available but future custom tools built for Flightstream will be added to this Ribbon as they become available.
The extension is supported from Hypermesh 2022.3 onwards.
Usage/Installation Instructions
Extract the archive in a local directory on the machine and add the extension to Hypermesh in the usual way.
