S-CONCRETE Batch Processing
In this video we will look at how we can use S-CONCRETE to perform concrete design checks on multiple SCO files without the need to interact with the interface.
We will also examine how to produce consolidated Engineering Design Reports.
If you'd like to use S-CONCRETE to design the concrete elements in your S-FRAME model, check out this video: https://www.youtube.com/watch?v=ndftT...
If you'd like to use S-CONCRETE alongside your ETABS analysis model, click here: https://www.youtube.com/watch?v=QyC6k...
