Overview
You can use the 2 example scripts attached from a Shell (Windows / Linux) to let it read a pre-definded session (also example attached) and export a screenshot or animation (select desired example script) of each session window.
Pre-Requisite
Save your session as .MVW that should be used subsequentially with this script.
Script "Batch_screenshots.tcl" will create a screenshot file for each window (JPEG).
Script "Batch_animations.tcl" will create an animation file for each window (GIF).
You can edit the file formats used in lines 88 and the resolution in lines 94 of the scripts.
Allowed formats for screenshots:
BMP and JPEG.
Allowed formats for animations:
"AVI", "AMF", and "GIF" (one file contains the entire animation) or "PNG", "JPEG", "BMP" and "TIFF" (a numbered series of still image files comprising the entire animation).
Usage/Installation Instructions
execute on Windows from Shell:
<ALTAIR_INSTALL>\hw\bin\win64\hw.exe -b -tcl <path-to-TCL>\Batch_screenshots.tcl -sessionfile example_session_Crash.mvw
execute on Linux from Shell:
<ALTAIR_INSTALL>/altair/scripts/hw -b -tcl <path-to-TCL>/Batch_screenshots.tcl -sessionfile example_session_Crash.mvw
Note that in later HW version the executable path is:
<ALTAIR_INSTALL>\hwdesktop\hw\bin\win64\hw.exe
Use "Batch_animations.tcl" accordingly.
The screenshot / animation files are created in SHELL folder.
