Tips and Tricks
Model setup and simulation run can often lead to mesh failure in FEM-based analysis.
Summary: Checking all the above points can help the user pass through the mesh failure stage without even facing it. Theses steps are the starter point for any Inspire Cast user who can check potential threats to mesh failure. Inspire Geometry sections allow users to solve these issues without going back to the CAD system. After these target issues are solved, the user can set up and run the simulation smoothly.
