There are situations in which you need to change the edge length of an element, or the distance between two nodes.
For example, to improve the mesh quality or to achieve a better representation of the topology.
In HyperMesh we can do this by selecting the Dimensioning option in the Measure Tool.
The measured distance and its components are displayed in text fields. These values can be changed as desired.
