Modal Analysis of the Cantilever beam using Altair Inspire
In this tutorial, we show you how to set-up, run & post-process the finite element analysis of a cantilever beam/structure. CAD design was modelled in such a way that the loads and boundary conditions can be applied smoothly on required region.
