In this video, we will continue with the modeling process described in the previous video (S-FRAME Multistory Builder - Floor Creation), and focus our attention on modeling in the vertical plane, elevation view. This includes creating elevation grids, group folders, and drawing objects in the vertical plane such as vertical bracing.
