In this comprehensive tutorial, discover how to utilize S-FRAME to design Fixed Offshore Platforms according to the API RP 2A - WSD 22 design code provisions. Dive into the world of offshore engineering as we explore the powerful capabilities of S-FRAME for structural analysis and design. Follow step-by-step demonstrations and learn how to analyze, and optimize your offshore platform using industry-standard guidelines. Whether you're an aspiring offshore engineer or a seasoned professional, this tutorial will equip you with the knowledge to efficiently design safe and reliable fixed offshore platforms.
