S-LINE is used to code check and design continuous reinforced concrete beams with one or multiple bays having unique sizes, rebar layouts, materials, loading, support, etc. The intuitive S-LINE user interface is built for efficiency and ease of use. This short tutorial explains how to configure the beam model in S-LINE. Topics covered include:
