Overview
This CADFEKO model is a triangle mesh of the inner layer of the IEEE SAM phantom. The minimum triangle length is 10mm. The model is set up for 1800 MHz. Roughly 2 GByte of RAM required.
Usage/Installation Instructions
Open model in CADFEKO.
