Overview
The model has 5 different media: brain, lungs, eyes, muscle and an outer air shell. The model contains 749,507 tetrahedrals (8 mm size) and can be used up to 1GHz. Requires more than 2 GBytes of RAM.
Usage/Installation Instructions
See included ReadMe.txt.
