Read contents of h5 and hdf5 files and write them in Excel workbook
When we are handling .h5 and .hdf5 files, which are useful for storing large amounts of data in any format, we may want to output all results into a more common file anyone can use (without any required knowledge).
In this tutorial I’ll show how all the contents from an .h5 file can be extracted and written into an Excel workbook in an orderly way. The input and output files as well as the script are added as attachments.
The first step for extracting data from a .h5 file is to have a look at its structure, as we need to know how to reach the relevant data within. The HDF5 Viewer Utility is very useful for this:
With this utility, we see that data is arranged in two main groups (Bottom and Top), each of these, in turn, contains relevant data about each element: Damage and another subgroup called Event_2 which contains the attributes NoOfCycles, RainflowData and RandomData. With this structure in mind, we can query all data from the file using loops. Let’s have a look at the script:
close all, clear, clc
filename = 'ElementRainflow.h5';
% Get all available groups
groups = readhdf5toc(filename)(:,2);
% Extract data from each group
for i = 1:numel(groups)
% Get all elements for this group
group = groups{i};
elements = readhdf5toc(filename, group)(:,2);
% Open .xlsx file to write outputs for this group
outputName = strcat(filename(1:end-3), '_', group(2:end), '.xlsx');
file = xlsopen(outputName, 1);
% Extract data from each element
for j = 1:numel(elements)
% Get all datatypes for this element
element = strcat(group, '/ElementId_', num2str(j), '_2D');
datatypes = readhdf5toc(filename, element)(:,2);
% Get total damage for this element
totalDamage = readhdf5(filename, datatypes{1}){1}.Damage;
% Get all datatypes inside Event_2
subdatatypes = readhdf5toc(filename, datatypes{2})(:,2);
% Extract rainflow and random data
RainflowData = readhdf5(filename, subdatatypes{2}){1};
RandomData = readhdf5(filename, subdatatypes{3}){1};
% Relevant data for writing output
Stress = RainflowData.('2_CycleId') + 1;
NumberOfCycles = RandomData.NoOfCycles;
Probability = RandomData.Probability;
StressAmplitude = RainflowData.('4_StressAmp');
MeanStress = RainflowData.('5_MeanStress');
Damage = RainflowData.('6_Damage');
CorrectedStressAmp = RainflowData.('7_CorrectedAmp');
% Format data for output
worksheet = ['Element ' num2str(j)];
headers = {'Stress', 'NumberOfCycles', 'Probability', 'Stress Amplitude', ...
'Mean Stress', 'Damage', 'CorrectedStressAmp'};
data = [Stress, NumberOfCycles, Probability, StressAmplitude, ...
MeanStress, Damage, CorrectedStressAmp];
% Write data
xlswrite(file, headers, worksheet, 'A1:G1');
xlswrite(file, data, worksheet, 'A2:G100');
end
% Close .xlsx file after writing
xlsclose(file);
end
Now we can share these Excel workbooks with anyone, doesn’t matter whether they know what an .h5 file is or not!
