This video covers the use of PSIM & InstaSPIN to determine the motor parameters of a PMSM motor. The technique is applicable to any three-phase motor. PSIM generates the '*.h' files the InstaSPIN uses. InstaSPIN is an observer algorithm from Texas Instruments.
