The PCB import tool in CADFEKO supports the following major ECAD file formats for import:
NOTE: The ECAD file formats are only supported on Microsoft Windows.
The PCB import tool also supports the PEMA (.pema) file format that allows closer integration with other Altair Simulation products.
NOTE: The PEMA file format is supported on both Microsoft Windows and Linux platforms.
