Users can define soils, with their corresponding types and properties, and apply them to different soil profiles. Soil elevation, water depth, and other properties can be determined, and new soil types can be added based on the USCS's categories and can be customized afterward. S-FOUNDATION's interface allows the user to switch between soils and soil profiles seamlessly.
