If you a have Windows machine you would like to execute code on, you can install OpenSSH and connect to the machine through the Altair SLC Communicate module. Altair SLC Communicate enables execution of code on a remote machine from a local machine.
Before you begin: Ensure Altair SLC Analytics is installed on both your local machine, and the remote Windows machine.
%LET myvm=remote-id; OPTIONS SSH_HOSTVALIDATION=NONE; SIGNON myvm SSH username="user-name" password="password" LAUNCHCMD="'path-to-install' -dmr"; RSUBMIT; %PUT &SYSHOSTNAME; %PUT 'Hello'; ENDRSUBMIT; SIGNOFF;
The supported options for Altair SLC Communicate are described in the Altair SLC Communicate user guide.
