When we are working on any project, it remains necessary to understand the properties of the sections we are using for executing all the subsequent calculations.
S-CALC's integrated features allow you to calculate section properties for non-standard reinforced concrete shapes and control the shape geometry to match any project needs, rebar positions, sizes, and materials, or even add holes to the concrete section if necessary.
In the video below, it is shown how to adjust and visualize a Reinforced Concrete section's properties
