Overview
In this example the Roll Over Protective Structures (ROPS) is simulated with Radioss..
The attached zip file contains the Radioss deck .
The attached PDF document describes the model, boundary conditions and brief description of the Regulation for that the Radioss analysis results are verified against.
The baseline model for this example was created by Prashanth A.R.
Pre-Requisite
Model was created and verified with HyperWorks 2022.0
In order to analyse the model, please use Radioss version 2022.0 or newer
Usage/Installation Instructions
Not specific needs
Post-Requisite
No specific needs
