This article presents a methodology to:
- Merge multiple result files into one xml
- Translate xml file into one H3D with Hvtrans tool
- (optionally) integrate a derived result
- (optionally) integrate a derived loadcase
All files used in the video are attached. Please, adapt filenames and directories.
NB: loadcases must have different ids.
