S-CALC can be used to calculate section properties for non-standard section geometry. These sections and their properties can be imported into S-FRAME and assigned to structural members for analysis. This tutorial shows how to transfer S-CALC sections to S-FRAME and assign these sections to members using the merge feature in S-FRAME.
