Overview
Split any selected 1D beams in half. Currently the split command will only split 1D elements if they are attached to 2D elements. This will split 1D elements independent of any shell elements. Related to Script 1013.
Usage/Installation Instructions
Used to split 1D elements in half.
Limitation
Will not split 2D elements.
Functionality
Meshing
Subfunctionality
1D Meshing
