Overview
Delta deformations between two structural meshes needs to be mapped into a CFD deformation.
Usage/Installation Instructions
Source the script and follow the video, play the slide in slide show mode.
Limitation
You can extend variations like pressure, force, enforced displacement, shapes etc... by modifying the macro.
Functionality
Utilities
Interface
Nastran,OptiStruct
