Overview
Hand over the ZOFFS info to ELMENET_SHELL_OFFSET after the using Nastran2LS-DYNA conversion.
Usage/Installation Instructions
1. Use the Nastran to Ls-Dyna convert.
2. File -> Run -> Tcl/Tk Script -> Select attached tcl file.
Functionality
Model/Analysis
Subfunctionality
Model Setup
Interface
LS-Dyna, Nastran
