This video explains how to add custom fonts to the server that may then be applied in dashboards and PDF report outputs. With release 2021.2 and above, dashboard designers with administrator access can upload TrueType or OpenType fonts to the server and use them in dashboards and PDF reports. The fonts will then be available to use in theme configurations or specific settings for dashboard parts.
