In this video tutorial you will find the detailed steps for a Shielded Cable Analysis using Feko.
This Article contains an attached pdf file for your reference along with the model files.
Here is the overview of the steps that are covered in the video tutorial.
The video shown below will walk you thru all the steps in the tutorial.
