On the Fly results using IMPLOUT
1.IMPLOUT basic parameters
Comments:
- If IMPLOUT is set to YES, then the separate *_impl.h3d file contains on-the-fly results during runtime.
- The following results are supported:
- Translational and Rotational Displacements are generally supported.
- Stresses (element, corner, and gauss), Strains (element, corner, gauss, thermal, plastic) are supported for first and second order solid elements and first order shell elements for both Small and Large Displacement Implicit Nonlinear Analysis.
- All output listed in (b) are supported for second order shells for Small Displacement Implicit nonlinear analysis.
- 1D CBAR/CBEAM/JOINTG elements are supported for both SMDISP and LGDISP for elemental stress and strain results.
- Contact results are generally supported for both SMDISP, LGDISP and for N2S and S2S contact.
- SPCFORCE is supported for both Small and Large Displacement Implicit Nonlinear Analysis.
- The following results are not supported:
- If MATS1 is present, then no elemental on-the-fly results are output for second order shells.
- on-the-fly elemental results are not output for second order shell elements for Large Displacement Implicit Nonlinear analysis.
2. Steps to follow
- Use search bar (press ctrl + F) > PARAM.
- Set PARAM>IMPLOUT>YES.
- IMPLOUT card will write impl.h3d file which create results dynamically during the run time.
3. Results
