S-LINE eliminates lengthy manual calculations for designing continuous concrete beam design. Design code checks will include results for each pay and highlight areas of interest or code noncompliance. This demonstration shows how to set up your continuous beam with multiple spans having different dimensions and reinforcement layout requirements. See how to specify
