Monarch’s table extraction function is designed for ordinary people who wish to do extraordinary things with PDF files. It enables business users to identify tables in text-heavy PDF files, select them, modify them as needed, and export the data to Monarch Data Prep Studio for further data transformation.
This short video shows you how to use the PDF Table Extractor in Monarch Data Prep Studio.
This video was produced using Monarch 2021.0.
