B. J.Glasser, J. G. Khinast, M. S. Siraj, S. Radl
Elsevier
Powder Technology
This study focuses on the understanding of flow over a single blade and its impact on powder mixing. The Discrete or Distinct Element Method (DEM) is used and the flow of a single blade through a bed of a binary particle mixture is studied. Mixing performance with respect to a blade-rake angle and particle size is investigated using the Modified Generalized Mean Mixing Index (MGMMI) and the maximum mean instantaneous velocities. A wide range of angles and different loading scenarios of the binary particle mixture were studied. Velocity profiles for all these cases were computed, as well as the forces on particles and the blade.The results showed an inverse relation between the interparticle force and blade-rake angle. Systems with a higher number of larger particles experienced a higher interparticle force. Similar results were obtained for the blade force. The results for mixing efficiency showed that if the smaller particles are placed at the top this leads to a higher mixing performance. The mixing performance was highest for blade-rake angles that offered a maximal surface area or maximal resistance to the flow of particles, which occurred for blade-rake angles from 70° to 90°.
Blade-rake angle, Bladed mixers, dem, MGMMI, Mixing performance
